Target Coatings, Inc.
Finishing Zone Forum Pages
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Black 6600 spraying clear
Post new topic   Reply to topic    Target Coatings, Inc. Forum Index -> Water-Based Spray Finishing Forum
View previous topic :: View next topic
Author Message
NewGreenie
PostPosted: Sun Apr 18, 2010 8:38 am    Post subject: Black 6600 spraying clear Reply with quote
Trying to finish a cabinet black using em6600. Its an oak plywood with poplar trim. Trying to get something like a black gloss piano finish.
When I called to order was told I should use 2 coats of em1000 sealer then as many coats of 6600 to build up finish and then 2 coats of clear gloss.
Sprayed sealer using a basic rockler hvlp with 1.5 tip. Waited over night and then tried spaying em6600 with 1.5 tip. Getting very little spray and switched to 1.8 tip which gave me almost to much but no black color. It sprays on clear with 1 shelve just a few light black steaks.
Please help with any idea s Thanks
Back to top
View user's profile Send private message
jonathanmahnken
PostPosted: Sun Apr 18, 2010 4:08 pm    Post subject: Reply with quote
mix it better????
Back to top
NewGreenie
PostPosted: Sun Apr 18, 2010 10:51 pm    Post subject: Reply with quote
Stirred up the em6600 good and checked with the viscosity cup of my sprayer. Got about 55 seconds so I swtched to a 2.0 tip and got a good black spray. Was able to get 6 coats on today and will put 2 coats of clear when I get a chance. It looks good not a glass piano class finish but will work. The oak grain from plywood shows but its sollid black and will match the speakers it will be next to.
Back to top
Robert
PostPosted: Mon Apr 19, 2010 3:20 pm    Post subject: Reply with quote
Timid to ask, but…. Is it me, I can’t find any of this EM6600 ( or any black topcoat) on the Finishing Zone ?
Can one advise me where to go, I need to buy this piano black top coat ?!
Back to top
jonathanmahnken
PostPosted: Mon Apr 19, 2010 3:34 pm    Post subject: Reply with quote
You have to call into the office to make the order. Make sure your gun will atomize really thick paint, almost as thick as interior latex. My low pressure guns had alot of trouble with the viscosity and I ended up having to use my airless with a 414 tip.
Back to top
Robert
PostPosted: Mon Apr 19, 2010 3:59 pm    Post subject: Reply with quote
Thanks Jonathan.
I'm Using a Devilbiss hvlp G-Plus (http://www.autorefinishdevilbiss.com/products.php?pg=1 ) with various tips (from 1.0 to 1.4mm ) on EM6000 up to the 9000 series without any trouble… actually love it !!
Would you say my 1.4mm tip would be the fit or I should thing buying bigger ?? ( 1.6 & 1.8 are available !?) Never tried interior latex with my guns !?
BTW, what is the viscosity level of this 6600 sealer !?
Thanks, Robert Wink
Back to top
jonathanmahnken
PostPosted: Mon Apr 19, 2010 8:41 pm    Post subject: Reply with quote
Have not measured the viscosity. I have heard that with a pressure fed you should go with a 1.8 and with a gravity fed you should go with a 2.0. I do know that it is far more viscous than any of the clears. Your devilbiss should do better with the thick stuff than my asturo ssp did, however It did shoot alot better through the ssp after thinning about 10% with distilled water. Do know that the 6600 is not topcoat rated and should be clear coated.
Back to top
Robert
PostPosted: Wed Apr 21, 2010 7:42 am    Post subject: Reply with quote
Sorry for this late reply…. I was out !
I’m thinking, first hand without yet consulting either Geff or anyone at Target, unsing the 6600 as a base ( +/- 4 coats ) then tone some reg 6000 with some black dye to give it sustain & depth for a few top coats ( +/- 2-3)….TBC & to be followed !!
Later, Robert
Back to top
Robert
PostPosted: Sat Jun 26, 2010 9:12 pm    Post subject: Reply with quote
Trouble in paradis !!
Got this EM6600 black ( EM6628) few weeks ago ( beginning may ) and never open it before today !!...and to my surprise, this is nothing I’ve ever seen !@ Shocked
Give & take it’s a heavy 250sec on my Ford 4 cup !!!???!!!
Calibration test before = 10sec w/water
4 test with this 6628, ½hr interval = all +/-250sec
Calibration test after all these with water and not cleaned cup = same 10-11sec !
By the way, room temp at 74F and humidity level at +/- 60%.
JEFF….. What’s this my friend ??
Call this “black” honey ….. not acrylic pigmented lacquer Mr. Green
What should I spray this with ??
I’m in deep %$?# !!....as I have no more extra time before delivery !
Can anyone tell / give me some advise !!
Later, Robert
Back to top
Jeff Weiss
Site Admin
PostPosted: Sun Jun 27, 2010 3:54 pm    Post subject: Reply with quote
Robert,
What size tip sets do you have for your spray gun?
_________________
Innovation Driven By Vision
Back to top
View user's profile Send private message Send e-mail Visit poster's website
Robert
PostPosted: Mon Jun 28, 2010 4:36 am    Post subject: Reply with quote
Hi Jeff,
Thanks for your reply on a Sunday !!
Basically, all available one from Devilbiss, from 1.0 to 1.8 (http://www.autorefinishdevilbiss.com/products.php?pg=1 )
But Jeff, What about this 250sec viscosity ?
I’ll need to call you this morning for some “live” solutions as time is no longer on my side…. I’m going to be late for delivery….crunch time Shocked
Later, Robert Wink
Back to top
Robert
PostPosted: Mon Jun 28, 2010 7:31 am    Post subject: Reply with quote
Hi again Jeff…
Called but was told you’re out for the day !
Left a message with my N° to call back.
Would really appreciate receiving a call back ASAP , since another issue has come up this time with a 5G pale of EM6600 received from the same order.
(I realize also you’re out and have other issues to deal with but….)
Thanks in advance for your time !
Robert Wink
Back to top
Jeff Weiss
Site Admin
PostPosted: Tue Jun 29, 2010 6:35 am    Post subject: Reply with quote
Robert,
The engineered viscosity of the EM6600 Black Lacquer is 70-75 ku, which is very heavy and not meant to be measured through a Ford Cup or a Zahns Cup smaller then a Zahns #5. do not confuse the viscosity of the clear EM6000 with that of the White EM6500 and Black EM6600. These tow lacquers require a much higher viscosity to maintain pigment dispersion.
I suggest that you use a 1.8 or 2.0mm tip set for spraying the EM6600 with a pressure feed gun. You can use a 2.0 or a 2.2mm tip in a gravity gun but it will be slow going.
JW
_________________
Back to top
Robert
PostPosted: Tue Jun 29, 2010 7:21 am    Post subject: Reply with quote
JEFF, thanks for this clarification.
One of the Problem I have, is nothing to compare or measure with this “KU ? ”.
Have charts comparing Poise, centipose, stokes, Zanhs, ISO, DIN….etc, but cannot find this KU !?
Don’t get me wrong, I’m not confusing viscosity of EM6000 with EM6628.
I may incorrectly explained myself, my new shipment of EM6000 has by it self viscosity discrepancy vs what I’m use to have ?
Sorry to mix two issues in this thread…..
Back to my EM6628, I have dissolve it a little bit with some EM6000 and spraying it with a 1.8 tip…..flows beautifully now !!
Let tell ya, this is going on MDF, and I hate MDF…. but at the same time, I’m spraying on some various veneer panels for test results, and so far this is VERY VERY nice on wood grain.
Nice quality mix you offer there Jeff, like this VERY MUCH !
Thanks, Robert Wink
Back to top
Robert
PostPosted: Wed Jul 21, 2010 7:46 am    Post subject: Reply with quote
No photos to share yet…. But needed to say thanks to Jeff and this forum for the support !
Finish a couple of week ago these commissioned pieces in piano black and yesterday night had to visit again the customer to pick up another order ( goes to tell they are V-pleased with the end result ).
After a total combine of 14 layers ( EM6628 + EM6000) and using 3M perfect-it polishing steps, this is as close to a piano black in polyester you will ever archive…..lots easier.
This is truly not as durable and resistant as polyester, but sooooo easy to work with, forgiving and to polish ( after proper cure time).
Plus, it makes it a little more affordable to other who wishes to get this piano black without the cost of associated to have it done in polyester…. As long they are advise & all fully understand, production lacquer is & will never be as durable as polyester !!
Recommend this 6628 to anyone and will use it again.
Cheers, Robert Wink
Back to top
Display posts from previous:
Post new topic   Reply to topic    Target Coatings, Inc. Forum Index -> Water-Based Spray Finishing Forum All times are GMT - 5 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
